I just got this Cellmeter 8 battery maintenance and servo tester. The instructions are sort of useless bc or the horrible syntax of a foreign translator. I am wanting to test servos for a 6 ch aircraft, and need to know what kind of battery to rig up for the test. I watched the main yt video for it, but they gloss over this part. As you can see on the top right, there is a 3 pin connector for a 5 v max input battery for the servo test. I also have the ubec pictured, which has high voltage input, but 5 v output that plugs into the meter, with open ends for different battery connections. Can i just plug in my 4s flight battery to the tails of this ubec, cutting it down to 5v, for testing my servos? Or do i need something different, like a specific 5 v battery to power the servo tester? Ive really browsed around and cant find the info i need. Thanks so much. For a dynam bf 110.
Cellmeter 8 servo tester batt quest.
