Plane goes to the left instead of rhe right
  • BruceV
    • Apr 2021
    Hi, i have the combo F16 camo high performance and the Futaba 6k 8 channel and the Eagle A3-L V2 3 Axis Airplane Gyro
    if i turn to left on the ground plane goes to the right.
    i tried to change it in the setup of the Eagle A3.
    can i change it in my radio ore are the wires the problem?
    Thanks a lot.
    This item: Freewing F-16 V2 Arctic Camo High Performance 70mm EDF Jet – PNP
  • RRHandy
    Instructor Pilot
    • 892
    • Lilburn GA
    Just reverse the channel in the radio.
    AMA 424553
    • Gilatrout
      RC Pilot Addict
      • 806
      • Albuquerque NM
      Thanks a lot.
      Is this a first jet? How long have you been flying?
      • BruceV
        • Apr 2021
        Yes, it is my first plane.
        Should i look for an other plane? Wich one?
        On the RF Simulator it goes well.
        RRHandy, i have found it. Thanks
        • fhhuber
          • Aug 2015
          • 1476
          It is unclear from the original post as to what is going on.
          Is just the nosewheel turning the wrong way?
          That would need a mechanical solution, or plugging nosewheel steering in another channel, then mix rudder to that channel.
          Are you experiencing turn opposed to commanded ailerons while just below takeoff speed?
          That is "adverse yaw" which can be an aircraft destroyer if you do not learn the signs and what to do about it.
          Maybe its just a main wheel binding up and acting like you applid brakes to that side.
          Annoying but easy to fix by adjusting the wheel collar or other wheel retaining system... or you might need to brass tibe sleeve the wheel hub to renew the bearing surface.
          And there are other possible issues, including point of view perception disorientation.
          • fhhuber
            • Aug 2015
            • 1476
            An F16 is a poor choice as a first RC model. The gyro can help, but it's normal to recommend a model that looks much like a Piper Cub or Cessna 152 as the first RC airplane.
            • kallend
              • 1871
              Would you choose to fly a high performance jet fighter as your first plane if flying full-size aircraft?
