Zohd Problem.
  • Billy Button
    • Apr 2021
    Zohd Problem.
    I hope someone can help me with this problem. I have a zohd copilot light which I have installed in a bixler connected to a radio master receiver and when set up at home with no stat lock everything works fine I get the correct lights for stab off, stab on and return to home. The stabilised mode works fine in all the correct movements. But when I whent to fly with a sat lock and I checked out the stab off, stab on again all was good but when I switched to return to home mode both the airlions jitter badly and the elevator goes to the up position. All goes back to normal when I put it stabilised mode or stabilised off position.
    So I could not fly like this. And I haven’t a clue what the problem is.
    I would be very grateful if anyone has any ideas on this problem.
    Thanks Mike.
  • Basura Solamente
    • Apr 2021
    Chattering in RTH is normal and confirms that RTH is working. You are good to go!
    • Billy Button
      • Apr 2021
      Thank you. That’s great news.
