Satellite receiver
  • f4u ausie
    • 1242
    • Melbourne
    Satellite receiver
    hi guys. Watch tons of rc u tube stuff,, like it also not in a club here.... question being a satelite rx connected to a lemon receiver .. or better a lemon rx with a satelite rx conected.. is this simply improving reception or is there more to it..... it was in a al 37 from fwing
  • SanExup
    • 912
    • Western Wy.
    f4u ausie I can't answer to whether the remote sat rx's can do more than just a redundancy to improve reception. I do know some of them are more specific to using with telemetry. But I think improved reception is the main function. Maybe other people will chime in on the specifics.
    I can say that I have installed them in a few of my planes. The criteria for deciding to use them, if they are big, fast, or expensive, I will install them. They are easy to install and bring peace of mind having antenna further away from the battery and esc. Cheers!
      What SanExup said
      • Daryl
        • Aug 2020
        • 48
        • Calgary, AB
        Are Spektrum/JR satellites compatible with Admiral receivers?
          • 8835
          A satellite RX allows for coverage of more spatial planes (not the flying kind). You place the sat so that its antennas point in different directions from the main RX, usually 90 degrees. Also, if the main RX is a location that has a lot of electrical gear near it, a sat can be placed in a more isolated location.
          I believe that any DSMX sat is compatible with any DSMX main. You'll find out quick enough if the sat lights up when you bind both to the plane (now the flying kind). I don't think you should mix DSMX and DSM2.
          • Gilatrout
            RC Pilot Addict
            • 806
            • Albuquerque NM
            I have no idea, but it is relevant that spektrum sells 2 models of remote receivers. One uses xbus to connect to the main receiver, the other uses srxl2.
            Any connections with a remote receiver will need to use the appropriate connection type.
