Introducing Motionsic B.A.G. (BadAss Gimbal) the most practical FPV mini pan & tilt gimbal to transform any RC warbird or EDF jet into your personal fighter plane.
Designed for use with DJI FPV Camera/Air Unit, it’s compact, fast, smooth, precise, easy to install, pans 280° to see 360°, easy to adjust camera to scale pilot eye level and dampens vibrations.
It fits easily under most RC plane canopies 40” wingspan and up. Can also be installed on RC cars, tanks, boats, or copters for use with a head-tracker to give realistic in-cockpit visual experience.
Check it out @ www.fpvdogfight.com
Attributes:
Compact - fits under most RC plane canopies, needs only cylindrical space 40mm diameter, 50mm tall for full movement with the FPV camera
Easy to install - use included screws and nuts to affix camera and platform to plane in minutes
Smooth/precise movement - includes 2x all-metal gear, digital, premium ball-bearing servos made by Savox in Taiwan
Check six for bandits - our custom servos allow the camera to pan 280° to see 360° (with camera field of view) and tilt up to 80°
Easy to adjust camera height/level to scale pilot eye position by adding/removing foam pads and adjusting the tightness of individual screws on corners of the platform.
Dampens vibration - foam pads also dampen vibrations from runway or road surfaces to make the visual experience pleasantly smooth.
UV resistant frame - impregnated with anti-UV polymer so gimbal frame stays robust with prolonged sun exposure.
Shock resistant - built to withstand minorplane crashes and keep on working!
Patent pending, Made in Taiwan
* DJI FPV Air Unit/Camera not included
example video showing smoothness of movement:
