This is such a great device! Just plug it into your s-bus capable receiver, and you'll have 16 channel at your disposal. For around 20 bucks.
I typically use standard 8-channel receivers, but occasionally I need just one or two extra channels. My radio and all my receivers can handle 16 channels standard, but you only get 8 ppm output connectors on the receivers. Up to now, I bought the Redundancy Bus RB20 devices, or the more simple 4-channel s-bus decoders to have all of my 16 channels available for ppm. But now this device is a lot more interesting. The 4-channel decoders need to be programmed (to select which ppm channel goes to which output), and the RB-20 (or even the RB10) cost quite a bit more then this one. For about the same price as the 4-channel decoder, I have this device now, much easier.
