LIghting Connectors
  • RC Griz
    • Dec 2020
    • 5
    LIghting Connectors
    I've got a model (Freewing P-38 Lightning) that has several connectors for the lights that are like 2-pin versions of servo connections. Just red and black wires. I'm trying to find extensions for these but I don't ever know what they're called to do a google search. Can someone point me in the correct direction??
    • 5426
    They are very similar to servo extensions as you note and that's what I use when I need one. I use a dremel or scissors to trim the signal pin side off the connector and remove the shroud around the male end. Hope that makes sense.
    You can find some if you search like in this link.
    Freewing 80mm EDF L-39 Albatros LED Light Set [FJ2151113] Motion RC
    • RC Griz
      • Dec 2020
      • 5
      That's what I may need to do - if I just use a unmodified servo connector it wont fit into the control board of the P-38. I'll try to trim one! Thanks.
