Multiple sbus connections
  • Koko
    • Aug 2022
    • 6
    Hello!
    Say I have a receiver, satellite and a gyro, how do I connect them all together via sbus when each only has one sbus port?
    Thanks!
  • Flash Jorden
    • 77
    What do you mean by satellite? I personally don't know of any S.Bus receivers that utilize satellites. Can you give an example of the actual hardware you have in mind?
      • 5426
      There are DSM2/X receivers that have SBUS and also can use satellites. Not just Spektrum but also Redcon, Orange and iRanger that I know of.
      If you are thinking Futaba, no they don't.
      • Flash Jorden
        • 77
        Ahhh, yes, I was thinking Futaba/FrSky. I thought Spektrum didn't call theirs S.Bus. My bad.
        • Koko
          • Aug 2022
          • 6
          Thanks for all your replies. I use Frsky products and was under the assumption that they had satellite products also. I found one YouTube video that showed how to set up receiver redundancy but it requires specific products.
          Thanks again!
          • mongo
            BFMA #13
            • Aug 2018
            • 38
            • midland, Texas
            no matter what happens with the other stuff, if you ever have to attach multiple units to a rx with just 1 port, most mfgrs make a buss port hub that allows you to accomplish this task.
            when they outlaw R/C, only outlaws will have R/C
