Hobby Eagle from receiver.
  • GWDawg1
    • Mar 2019
    No longer a problem, fixed it. ……….I am desperately trying to set up a Hobby Eagle Super 4 using switch SA on my Radiomaster TX16s using a Radiomaster R88 receiver. Can someone please walk me throujgh the process. I cannot get a signal from the recevier to the gyro. Everything else seems find. Any help would be appreciated.
  • serpentracer
    • Nov 2019
    • 112
    • Ohio
    you should post the fix in case someone else has a issue
    • serpentracer
      • Nov 2019
      • 112
      • Ohio
      after installing one of these gyros in a plane, I quickly found out you HAVE to have the controls in the radio set up exactly how they show or you may not get it to switch modes or connect to the receiver.
      I would highly recommend talking directly with hobbyeagle about your issues.
      • andree23
        Banned
        • Jul 2023
        • 6
        Consult the manual for the Hobby Eagle Super 4 gyro for specific setup instructions. This typically involves configuring the gyro's sensitivity, mode, and other parameters. The configuration process may include using a programming card or connecting to a PC if supported by the gyro.
        • kallend
          • 1871
          Is ChatGPT back among us?
