Hobbywing skywalker 80amp Uber esc issues
  • JT83
    Talk to me gooae
    • Aug 2020
    • 16
    • Mn
    hello need help with my esc. Trying to run 2 3s. 5200 80c lipos got them on a parallel wire harnesss. With the sknetic bison xt V1 using a spektrum ar8360t rx plane is very under powered I tried manually putting the esc into 6s manually through programming didn’t work any suggestions also I have a white black 2 pin wire lead coming off the bec is that for reverse thrust?
    • 5426
    You are doing a parallel adapter, that gets you 10400mAh 3S. You need a series adapter.
    "Trying to run 2 3s. 5200 80c lipos got them on a parallel wire harnesss​"
    • JT83
      Talk to me gooae
      • Aug 2020
      • 16
      • Mn
      Ok, cool I’ll give that a try thanks for the input cheers!!
