Spetrum ar620 and dxs transmitter
  • eugeniopatel
    • Jul 2024
    Hello,
    I have a spektrum dxs transmitter from a rtf plane I bought,
    I am trying to use the transmitter with a new plane that I have put an ar620 in. All works fine apart from the ailerons and elevators and reversed and the dxs has no way that I can see of reversing the channels.
    Does anyone have any idea what I can do? I had assumed that there would be no issues with spektrum to spektrum so this has puzzled me.
    I am trying to setup a trainer system using a module that sits in the plane, all works perfectly apart from this reverse issue.​
  • kallend
    • 1877
    Page 7 of the manual.
    • shortround91
      • Nov 2023
      • 301
      • Princess Anne, Maryland
      Very easy fix go to menu icon on servo set up scroll over there will be 2 or 3 options one will allow you to reverse the selected servo and motor directions. Make sure to relearn servo orientation afterwards or things will work backward ms for AS3x and safe. Been there with a very violent crash followed she went straight up then straight down one of the worst crashes I’ve had to date
      • kallend
        • 1877
        His AR620 does not have AS3X or SAFE.
        • shortround91
          • Nov 2023
          • 301
          Is it the AR630 can’t remember I’ve gone to 6-8-10 channel receivers now
          • kallend
            • 1877
            ? Is what the AR630?
            The AR630 IS a 6 channel receiver. It has AS3X and SAFE but it is not the one the OP says he has in his model.
