AR 631 AS3X correcting rudder in wrong direction.
  • Simon Bee
    • Oct 2021
    • 135
    • Leeds UK
    Just bought a new AR631 for my Tucano. I’ve used forward planning quite a few times so I’m quite familiar with setting up aircraft. However this time I cannot get the rudder to correct in the right direction, ailerons and elevators are fine. I’ve reset to factory settings twice and the orientation of the rx. looks fine but the rudder is still correcting in the wrong direction.
    Anybody any ideas ?
  • kallend
    • 1877
    Is it updated to AS3X+ ?
    • f4u ausie
      • 1240
      • Melbourne
      I had that with my ar 631 forward programming.. took a week to sort.. its a while ago so bear with me... i stood it on its nose did every thing,, over and over.. each time an option appeared to reverse things, i was ignoring it.. not a good help,, i no but point is, dont ignore something u c pop up as u go thru it.. its an f4 fwing 90 8s goes great now.. likely next time i may have same trouble,, MY FIRST AS3X SETUP mine is not asx3 + GOOD LUCK
      • Simon Bee
        • Oct 2021
        • 135
        • Leeds UK
        thanks for the reply. I’ve sorted it now. Eventually I realised that I had bound the rx to the aircraft with the rudder movement reversed. I had to reset forward planning to factory, correct the rudder direction and rebind 👍
        • f4u ausie
          • 1240
          • Melbourne
          I think that's what I did
          • kallend
            • 1877
            You don't have to do a full factory reset (which involves re-entering all the gain values etc.). All you need do is "Relearn Servo Settings".
