Binding the LEMON 7 ch rcvr/gyro to the Spektrum DX8 seems to work 100%; Programming the gyro stabilization is something else! Followed the steps in the manual (pg 5) and quick start - rcvr part seems to work OK! Cannot get the stab to function period! What's the trick? Watched several videos - none show the BLUE light switch on/off which activates the gyro/stab activation via the GEAR sw on the rcvr - that I can see. I put the bind plug in the right place (ch 5) and turned the rcvr power on - hit SW C while powering on - lights flash let go SW C then hit it once - nothing changes. If anyone knows he trick - please share.
Lemon 7ch Rcvr/Gyro
On your TX, can you scroll down to "telemetry" and then go into the telemetry menu to open up and activate the available features? You have the RX that has the voltage sensor probe, right?Originally posted by Yellowred View PostHi, I have one of these receivers using with my Nx8+, binds ok but can't get the telemetry screen up to program it through the tx, watched lots of vids, I have it in an EDF with elevons, hours going round and round getting nowhere, anyone help? Thanks
The voltage probe plugs into the small port on top. There are 2 such ports. One says "SAT" - It's NOT that one. V probe goes into the other one. Take note of the pins as they are more to one side than the other. The other single pin goes into the red wire of the battery balance plug. That should give you the volts for the whole pack. Be mindful of the voltage sage when you use high throttle. The more indicative reading is during a cruising level pass.
What's "TEC GEN"? Never heard of it.
You do know that telemetry will only tell you what is set into the RX. IE ...................... Vario, Altimeter, Energy meter (Requires V/I sensor) and Internal Temperature Sensor.
Yes Thanks, im having ti press the little button C and watch the lights flash to try to get it to work, pointless having a modern transmitter and watching lights flash! anyway, I have got it to work but the giro is only working one elevon for elevator and the other elevon for airlons!!! Don't know what's left to cure this? When I bought it I thought it would be easy to adjust on the transmitter but NO
This generally happens when you declare "elevon" in BOTH the gyro RX AND in the TX. The TX must be set to "normal wing/tail".Originally posted by Yellowred View PostI have got it to work but the giro is only working one elevon for elevator and the other elevon for airlons!!! Don't know what's left to cure this?
