Lemon RX
  • Claude
    • Mar 2026
    Lemon RX
    My rx binds ok with my DX8 but the rudder and elevator act like it is for a elevon airplane. I rechecked the transmitter by creating a new airplane with comventional ailerons but the rudder and elevator anot acting like a conventional wing. Does anyone have an idea how I can fix this?
    • 8835
    I think that somehow, you pushed buttons in the Lemon RX in such a way as to tell it you have "elevons". Check the instructions to change it to normal ailerons. If you don't have the instructions, go to Lemon.com and download a manual for your particular RX.
    Oh, how do you have your AIL connected? Are they "Y'd" or do you have each aileron in a separate channel?
      • 8835
      OK, I should have asked. What kind of plane is it? Did you check the Lemon to make sure that it's configured for the correct type of wing and tail? Your DX8 should also be configured correctly. You say "conventional aileron", but what does this mean? It should say something like "1 AIL, normal tail". What does yours say? And where is everything plugged into (aileron, elevator, rudder - on a Lemon, those should be port 2, 3, 4).
      • kallend
        • 1877
        Which Lemon RX is it?
        If you post the SPM file from your DX8, others can load it and see what's going on there.
