Servo Question!
  • Boots Whirlygig
    • 560
    • Granville Ohio USA
    Servo Question!
    I searched the squawk, but I get sidetracked reading all the great information, laughing at how everyone on here gets along like you've known each other for a lifetime! And I'm really learning a lot from you all. But I'm still making dumb mistakes. Here's my servo question: Can you change the direction of a servo by switching the wires, making rotate in the opposite direction? Thank you!:Confused:
    • 2818
    • Arlington, TX
    Yes, but you have to be sure to switch the wires both on the motor, and on the potentiometer inside the servo. Here is a quick video on how it can be done:
    Have done this to quite a few servos for various projects, and have had no issues.
    • Boots Whirlygig
      • 560
      Geez. And I thought replacing a motor in a tiny quad copter was tedious! Thanks!
      • doctormike
        HobbySquawk Moderator
        • Oct 2013
        • 1260
        • Santa Fe NM
        I guess I'm lazy. Why not just buy a reverse servo for a few dollars?.....Unless, of course, you just enjoy electronic tinkering. Doc
        • Boots Whirlygig
          • 560
          No Doc, I am lazy! I thought you could simply swap a couple wires at the plug, not having to perform micro surgery!! There's NO WAY I'd trust the servo I operated on! Talk about stress! Bwahahaha!
            I do this all the time with no issues at all.
            • Prowler901
              • 940
              • Gunnison, CO
              It always seems that I can't find reversed servos in the size I need, or they are out of stock. So, I just buy extra servos and reverse them myself. It isn't really as hard/tedious as it looks.
              • doctormike
                • Oct 2013
                • 1260
                • Santa Fe NM
                Actually, it might be fun.:)Doc
                • Prowler901
                  • 940
                  • Gunnison, CO
                  That's the spirit! :Cool:
                    And they will be the same speed and travel limits.
                    • Boots Whirlygig
                      • 560
                      I successfully replaced a motor in a tiny Quadcopter. I don't have a soldering station and used a small iron that I filed to a finer point, which still seemed to big to get into that little area. The wire was about the size of frog hair. Tedious but I was successful, so I'm sure I could do it if push comes to shove!
