Binding issues
  • Eslahrocks
    Binding issues
    I received a brand new dynam primo. Rtf. When trying to bind the red light never stops blinking and there's a loud steady beep noise.am I doing something wrong or is the reciever broke. First time flyer
  • Hippie 64
    • Feb 2014
    • 1049
    • Gaffney , S.C.
    Sounds like the throttle is in the up position when you plug in the battery . Turn on radio make sure throttle is down then plug in the plane battery
    Bryan
    But Crashing is Landing
    • RRHandy
      Instructor Pilot
      • 898
      • Lilburn GA
      That would also include the trim all the way down. ;):Cool:
      AMA 424553
      • Eslahrocks
        I've tried throttle up trim up throttle down trim down.the receiver never stops blinking and the motor has a short beep every two seconds. And the motor moves alittle bit when it beeps
        • dahawk
          Augermeister
          • Jun 2013
          • 1006
          • Keller,Texas
          Try moving about 3-4 ft away
          • Hippie 64
            • Feb 2014
            • 1049
            • Gaffney , S.C.
            Try starting with the throttle in low position move it all the up then back down . Some rec. need to be initiated . May work I'm not sure on the Gavin radio equipment yet. After opening the Manuel on the website it instructs on using a Binding plug . Did it come with one ? If you go to the MRC website and look in Electronics go to radios there is a Gavin 6 channel there . Pull it up and on the right side is a place to open the Manuel Not sure if this will help but worth looking into
            • ryramZ
              Pilot Ryan
              • Dec 2012
              • 814
              Binding procedure at 2:17. Should be similar. If following that doesn't work you will need to make sure all of your connections are good. Mainly esc to motor first, check your bullett connections. Sometimes one gets unplugged. After that I would still follow along the with the Gavin 6c program guide video, even though you have the 6a.
                • 7437
                I've found that moving the throttle to the lowest position sometimes isn't enough, roll your throttle trim back as well. I always fought to get the Spektrums to bind, but interestingly, the Lemon Rx I put in the Tigercat bound right off the bat.
                Hope that helps.
                • RRHandy
                  Instructor Pilot
                  • 898
                  • Lilburn GA
                  Hope that helps.
                  Covered post #3. :Cool:
                  AMA 424553
