Changing End Points Explained for A3 Pro SE
  • Mike S
    I contact Hobby Eagle and they explained they modified
    the software for greater rotation stability over the A3 Pro
    previous version. They purposely increased the endpoints,
    going from deactivated to 2D and from 2D to 3D for greater
    stability in the air. I found the best way to set this gyro up
    is to adjust the trim buttons on the front of the transmitter
    to neutral, put subtrims at zero, then mechanically adjust
    surfaces to neutral, then center the sticks. There should be
    no movement switching from 2D to 3D on the ground .
