Eagle A3 Pro SE
  • JimBoney
    Eagle A3 Pro SE
    was going to try using gyro on a 800mm t-28 only cause I have one lying around wanted to try it out ,, Using 4 ch spectrum AR400 . does the receiver need to be at least 5 ch for the A3 Pro to work ... any help appreciated
    JIm B
  • StarHopper
    • Aug 2013
    • 230
    Re: Eagle A3 Pro SE
    You'll need a 5 channel in order to switch modes, (Stable, 3D, Off, ie a 3-pos switch) otherwise you will be 'stuck' in 'on' mode full time.
    • boomer108
      Chief Boom
      • Apr 2014
      • 868
      • Chicago IL.
      Re: Eagle A3 Pro SE
      I just bought the new Eagle 3L from Motion and I have a Tactic 650 transmitter and a Tactic 6 channel receiver. The gyro will work fine on my Flyzone Sensei as it only uses only four channels and you need at least 5. But if I want to use it on my FMS Corsair 1400 which uses 6 channels, I will need to upgrade to at least a 7 channel radio or better yet 8 channel which hopefully Tactic comes out with soon. The mode selection is a must if you want to control your modes with your radio. The remote gain control channel however is only needed if you want change the % of gain with your radio instead of manually on the gyro. It is not needed for the gyro to function. Good flying!
      Roy B.
      • JimBoney
        Re: Eagle A3 Pro SE
        Thanks Starhpper kind of thought so ... Later bro
