I need help from an expert member. Can any member suggests to me which paint stripper is the best for wood and metal?
Need Best Paint Stripper
Depends. What kind of paint and how big of an area? Is this for a model or some larger project? There are solvents that work pretty well on smaller areas but if you’re stripping a large area or furniture with grooves and carvings you can get reallly good results with various purpose strippers from your local hardware store. Some projects can also be accomplished by mechanical means, ie. sandpaper, grinder, sandblasting, pressure washer, etc....Comment
There are number of things that we can consider over here. As a matter of fact, the best paint stripper can be the one which stands out the best and has the required characteristic, you can check more information about it over hereComment
I believe the active ingredient in paint stripper has been much reduced. Nitromors is crap compared to what it was. I bought a heavy-duty paint stripper from a local automotive paint supplier in Chester, which was £30 a gallon that worked well. There is Starchem Synstryp.
Personally, I think it's great to have your kids involved, but maybe painting not paint stripping is more appropriate. As adults, we have to protect ourselves from this stuff.Comment
