Absolute Best Wire Connectors for Lipo, NiMH. Soldering wire together! Period.
  • Absolute Best Wire Connectors for Lipo, NiMH. Soldering wire together! Period.
    These little connectors are the connection of the future. All you do is heat, watch it solder the two wires together. Also, makes them water-tight! Click image for larger version
    It's hard to tell what it is just based on the photo.
      You insert the wire into the correct size connector in the photo. Then, you heat them, with a mini torch. The solder in the center of the connector melts. It then shrinks to seal each side of the connection around the wire. Hope this makes sense. Instead of using a Crimpt connector that can attach two wires back together. It's an easy solder connector to attach two wires back together. You insert the wire into each side of the connector. Then just apply heat. It will make a solid electrical wire connection. Just like soldering two wires together. Then you have to have a heat shrink to cover the connection.
        Thanks, yes I understand the concept, where did you get them?
          Just google solder wire connector and you'll get all kinds of sources like Amazon etcetera
            Correct-a mondo! I guess I should have mentioned that. They work as advertised. OV10 knows all this, a true RC Guru! Thanks, OV10!
              Yes, amazon.com. Dang, I was going to say that only Government workers can get them and, they are super expensive..."Then, tell you I was joking! 😂😂😂 OV10 ruined my Goofy opportunity.
