Photos
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    Photos
    How do I put in a photo with my posts? I can't find any info on this. Thanks The Doctor
  • Lon
    • Jul 2014
    • 1201
    • Miles, Iowa
    RE: Photos
    [hr]
    I used the new attachment...you just have to make sure the file isn't too big in size.
    Lon
    • Rocketeer
      • Feb 2014
      • 1356
      RE: Photos
      Greetings,
      To insert a photo into your posts,
      1. In the New Attachment window, Click the Browse Button to obtain the desired photo/file.
      2. Dbl Click on the desired photo/file and confirm its location appears in the Browse window.
      3. On the Right, click Add Attachment
      4. The photo/file will now appear at the bottom of the New Attachment window.
      5. On the Right, Click Insert Into Post
      6. Move the Bracketed photo/file with ID number to desired location within the post.
      7. Hit Preview Post to check contend
      8. When happy, Click Post Reply
      Example
      Hope this helps
      Bill L.
      in Okla.
      • doctormike
        • Oct 2013
        • 1260
        • Santa Fe NM
        RE: Photos
        Thanks, Rocketeer. I'll give it a try as soon as I pick out a photo. I just want a photo that appears next to my posts. I'm not computer savy. The Doctor
        • Rocketeer
          • Feb 2014
          • 1356
          RE: Photos
          Greetings Doc,
          I'm sure you're already aware, but when you have decided on your Avatar (the photo that accompanies your posts), just go to your control panel (User CP) and select Change Avatar. Then Browse to your photo, double click the file name to insert it into the browse window and finally click Change Avatar.
          The fun part of that is you can change it as often as you like. Enjoy!!
          Clear Skies
          Bill L.
          in OKla.
