Will some one give me some tips on how to measure the CG on the F5N? I usually use a Dubro CG machine to measure the CG; however, the CG for this plane is out of range for this plane. I am using the recommended battery. Thanks much.
CG for F5N
RE: CG for F5N
Maybe try a Vanessa CG machineOriginally posted by PheonixWill some one give me some tips on how to measure the CG on the F5N? I usually use a Dubro CG machine to measure the CG; however, the CG for this plane is out of range for this plane. I am using the recommended battery. Thanks much.
RE: CG for F5N
Thanks but I do not have room to make one of these.Originally posted by WintrSolMaybe try a Vanessa CG machineOriginally posted by PheonixWill some one give me some tips on how to measure the CG on the F5N? I usually use a Dubro CG machine to measure the CG; however, the CG for this plane is out of range for this plane. I am using the recommended battery. Thanks much.
