Don’t see an area for modifications and building so I’ll post here......
I have a question and am not too sure where to turn. I’m adding details to Dynams Hawker Tempest and finding a balance between real life and the duty the model will perform needs to be a balance (like weathering, I guess). I’m adding flaps and have successfully cut the foam down with a dremel and router bit to a certain depth to allow a thin plastic ‘floor’ to support the thinned foam above and then have a 1.5 to 2mm flap. So the question is the real aircraft flaps run from the wing root to the aeilrons and are split into 2 flap sections. They angle at the split which will cause binding when they deploy which can most likely be clearanced so I’m not too worried about that. Moreso wondering if a flap that long (to be inline with the real plane) is overkill or detrimental to a rc flyer?
What I lack is experience in flying different acft with different configurations so I cant make a judgement on the full length as opposed to the inner only area for the flaps. I have the pockets cut out for the inner flaps and figure if I do the outter also I’ll need to use 2 9 gram servos per side to deploy. Does this sound reasonable?
I know it might be much to hypothesize an answer but any comment would be appreciated.
