Aluminum covering?
  • CVA59
    A4 Driver
    • Nov 2018
    • 398
    • Texas
    Aluminum covering?
    Has anyone ever tried using HVAC aluminum foil tape or equivalent on one of these foam jets? If so, please share your results. Thanks
    EAA# 1366802
    AMA# 631508
    https://vf59.weebly.com/
  • RRHandy
    Instructor Pilot
    • 896
    • Lilburn GA
    You can use it, same product, same procedure.
    AMA 424553
      • 2818
      • Arlington, TX
      I have not used it on a jet yet, but I did use it to cover my LX B-25.
      • CVA59
        A4 Driver
        • Nov 2018
        • 398
        • Texas
        What product did you guys use?
        EAA# 1366802
        AMA# 631508
          • 2818
          • Arlington, TX
          I used this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
          • IfIHadWings
            Eat, fly, dream, repeat.
            • Jan 2015
            • 63
            • Jefferson, GA
ID:	224846 HVAC tape worked well on my FMS B-25. I wasn’t sure if the metal would interfere with the Orange Rx, so I mounted it in the top turret with the antenna beyond the fuse. No problems and the tape has held up well.
            GP Sport Zero, scratch built MA Sky Skimmer, VQ SBD, Eflite Pulse XT & RV-9, FW Stinger 64, Hanger 9 Saratoga, GP P6-E Hawk, FMS Stuka & B-25, Lanyu Do335, PZ Albatros, Eflite Hurricane 25e, Airfield F4-U, Freewing P-51D, Dynam Tempest, Bf-110 & 182, GWS Mustang & Formosa, FZ Switch, Eflite L-4, RocHobby Critical Mass, Alien Aircraft Gadget, RCM&E scratch built CanDoo, Dynaflite Piece O’Cake, HK Ventus, FZ Beaver, Avios Sea Fury, Uravitch 52" OV-10, Herr Engineering J-3
            • CVA59
              A4 Driver
              • Nov 2018
              • 398
              • Texas
              That is quite impressive. Do you notice any flight characteristic changes with the added weight?
              EAA# 1366802
              AMA# 631508
                Elbee commented
                Editing a comment
                CVA59, that is simply beautiful work, Sir. Bravo Zulu. Best, LB
            • IfIHadWings
              • Jan 2015
              • 63
              • Jefferson, GA
              Thanks CVA59. Not that I recall, but truth be told, I had wrecked the Mitchell and took the opportunity to add flaps (https://www.rcgroups.com/forums/.php...-B-25-flap-mod) and the foil. The remaiden involved an entirely different airplane.
              • CVA59
                A4 Driver
                • Nov 2018
                • 398
                • Texas
                NICE JOB!!!!! Very impressive.
                EAA# 1366802
                AMA# 631508
                • cashmoneybrother
                  • Aug 2017
                  • 69
                    • 7417
                    Just covering a P-40 fuse with the taper version of Flite metal, I.E. chrome duct tape, just for something to do to while away the time.
                    I have Flite Metaled a FL P-51.
ID:	246680Click image for larger version
                    She's a little rough now as she augured in and sat until I got up the guts to rebuild her. Seems to fly better now.
                    Before the crash Click image for larger version
