I noticed an error in a diagram I attached to a post a while back, and can't figure out how to replace it with a corrected version. I tried PM-ing the moderator of the forum, but I get an error message telling me his inbox is maxed out. Any help would be appreciated.
Need Help To Update/Correct Attachment
Where is the Original Post and what is the Post Number? Also, did you click the"edit" button (Lower Right) on your post. This should allow you to "Remove" the document and replace it with the corrected version. Best, LB"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446 -
5th image attachment at:
Motion RC is proud to announce FlightLineRC, a new brand of warbirds developed in partnership with Freewing Models. Freewing has established itself as a premier
Need to replace it with a corrected diagram. There is no Edit button. I read somewhere that after a couple of weeks of posting, you can no longer edit, so I suppose that’s why there isn’t an Edit button. And I only want to replace the one image, not the entire post.Comment
Is it the schematic with the 2 motors and ESCs or the Photo with your additions in white? I can remove the attachments; but I cannot add a corrected one if I do not have it Could you 'copy/paste' your text and then add all the attachments once more? I have to do that on more than one occasion myself. Best, LB
.png)
