FliteLine Hawker Sea Fury Paint Codes
    These are the LOWES Olympic paint sample codes.
    The pastel light green color on fuselage side and bottom of wing and horizontal stab:
    Satin acrylic enamel BASE 1 75502 101-1.75 , 102-1.5 , 107-7.75
    The dark sea grey color on the top of wing, fuselage and horizontal stab:
    Satin acrylic enamel BASE 5 75505 101-21.75 , 113-12.75 , 115-6.25 , 214-2
  • corsair167
    • 57
    • shortly, Ft Mill S. Carolina
    The light sea green was great...........the grey came out pink.
      I double checked the barcode label with the code numbers that I have listed and they are the same. Can't imagine that the Lowes paint sales clerk gave me an incorrect label because they are spit out from the machine that does the mix. Double check your label and see if your sales clerk input the correct/or all the numbers.
        How's this for service, snapped a pic of the actual label.
        • corsair167
          • 57
          Looks Grey to me, the guy missed something;m will try again. PS do you spray w/airbrush?
            The absolute fool proof on getting the grey is just unscrew/detach one of the horizontal stabs and have them scan the grey. The code should come to match as shown on the pic and as well as what I listed. If it doesn't correlate then I would question the clerks understanding of using the color scan machine. You also never indicated if your label matched up. If it doesn't then they owe you a correct mix or you possibly gave them the wrong info, this the only help I can further suggest from here.
            PS - I hand brush all my warbirds.
            • boomer108
              Chief Boom
              • Apr 2014
              • 868
              • Chicago IL.
              Hey OV10!
              . What kind of brush do you use?
                Hello Boomer,
                Nothing expensive, just economy grade artist stuff in a 3/8 wide fan and a 1/8 straight.
                  Originally posted by corsair167
                  has anyone else had an extremely tail-heavy Sea Fury? with a stock Admiral 4S 4ooo battery
                  I addressed and answered your exact concern in my build/flight review located here:
                  • corsair167
                    • 57
                    I never saw it until today. Mine was tail heavy too. In fact, it had (crashed) up thrust! 'the motor was shimmed with a washer for up instead of down. Emailed Motion today. As I did not purchase there, they could not warrenty the kit; however the LHS did. Scale Reproductions Hobby Shop in Louisville KY Buy at the L HS if you can,,,,,,,
                    • boomer108
                      Chief Boom
                      • Apr 2014
                      • 868
                      • Chicago IL.
                      Originally posted by OV10
                      Hello Boomer,
                      Thanks OV10, I'll give it a try.
