Spray paint
  • Dator2
    • 3
    Spray paint
    Hey guys, any one know what type of spray paint I can use on EPO foam planes. Something that I can get at a local store? Any help would be appreciated thanks. Dwayne
  • bradl4648
    Your Motion RC CS Team Rep
    • 369
    Hi you can use any spray paint on epo planes at this point now like krylon. Just go back a little farther than normal but your good to go.
    Hope this helps!
    • Capt. Crunch
      Balsa flies better
      • Nov 2014
      • 388
      • Iowa
      Hi Dwayne, I've had great luck with Valspar. Its a paint and primer all in one. It lays on really nice
      • doctormike
        HobbySquawk Moderator
        • Oct 2013
        • 1260
        • Santa Fe NM
        I use Krylon because it dries so quickly. After it is COMPLETELY dry, I give it one or two coats of Varathane waterbased clear gloss. Were talking a Beautiful finish! Doc
        • wvrailfan
          • Sep 2013
          • 682
          • West Virginia
          I've had good luck with Krylon, Rust-oleum, Valspar, ACE Hardware brand and Testors model spray paints. The real trick is getting the paint to stay on the foam. Make sure it is a clean as you can get it. I wipe EPO foam clean with acetone before painting. If you don't have acetone, clean the foam with rubbing alcohol.
          ​Jim
          • doctormike
            • Oct 2013
            • 1260
            • Santa Fe NM
            Yes...definately rub it down with alcohol. I also give it a coat of Varathane as a primer, before painting. After it dries I rub my hand over the plane to find any rough spots. I sand them lightly with 600 grit wet/dry paper, but I don't wet it. Doc
              • 7415
              I found, and I've stated it before, that if you put a coat of Varathane or Minwax on the plane, then rub it off with a rag, it removes the oil residue that the molds leave behind. I've done this on every plane that had any white/bare surfaces and it works great. Just rub it like you're polishing a shoe, let it dry and you're good to go.
              Pandora One is down with Acrylic Enamel that I picked up in the craft section of Wally world. Pandora Two was painted with Rustoleum Painter Touch Ultra Cover and Primer which worked well.
                • 2818
                • Arlington, TX
                I really like the Testors and Tamiya spray paints on epo. They stick very well, and generally have more selection of accurate colors for painting a warbird. I use the tamiya primer first as a base coat, and that even protects EPS from most spray paints.
                • Prowler901
                  • 940
                  • Gunnison, CO
                  Thanks for the info on the Tamiya primer. I have an old version of the FMS Alpha Jet that is EPS. I sprayed some Krylon primer on the old busted fuselage and it attacked the foam a bit. I think the new fuselage I bought is EPO. So more fun to be had. :)
                    Krylon now makes a Foam Primer, even has an airplane on the label...I've used it and it works great to seal bare areas and fills in the cell lines.
                    • Prowler901
                      • 940
                      • Gunnison, CO
                      I've looked for that here at Walmart and Michaels. No joy. I'm gonna have to order it online.
                        Let me know if you can't find any, the Michael's and Hobby Lobby here stock it.
                          • 7415
                          Think I'll have to get a can myself, sounds like a great product.
