Touch-up paint
    Touch-up paint
    I know most of us get our colors matched at Lowes or Home Depot but it never really matches perfectly, the color, sheen or texture is always a little off. I for one would be interested in a 3-5oz bottle of the actual paint used by the factory.
  • dkalwishky
    Warbird Lover
    • Sep 2015
    • 1382
    • Des Moines, IA
    I would also be interested in that.
    • AkumaZeto
      Achtung Stormtrooper
      • 907
      Yup me too
      AMA 1102566
      • RRHandy
        Instructor Pilot
        • 898
        • Lilburn GA
        Me also four
        AMA 424553
        • Prowler901
          • 940
          • Gunnison, CO
          Now that is an excellent idea!
          • Gilatrout
            RC Pilot Addict
            • 806
            • Albuquerque NM
            Yes please
              We'd love to provide something like this. We've looked into this several times in the past, and unfortunately it's a larger challenge than it might appear from the outside. I suspect that's why the other foam airplane companies like Horizon Hobby, Hobbico, don't offer foam touch up paint for their foam aircraft, either.
              Here's why:
              1) The paint sprayed on at the factory is not your average paint. Without getting into too much detail, it is formulated to be sprayed with an industrial spray gun. It cannot be shot through a typical hobby sized airbrush, and it does not brush on well. Sometimes a foam part will arrive with a bit of "touch up"; I'm sure some of you have seen this firsthand. The brushed on area never truly matches the painted on area, despite it being the exact same paint, in terms of sheen, texture, and evenness. What's more, the factory paint is not always completely opaque.
              2) Even if we were able to formulate a brush-on or airbrush-capable paint that matches the factory color and sheen, and somehow make an economic case for that initial investment, the largest hurdle would be importing that paint. Importing foam and electronics is one thing, but paint is an entirely different category because it is a liquid chemical. If I could only disclose the huge amount of time and money we spend annually on insurance and logistical challenges regarding the importation of batteries!! It makes the economics of bringing in a few jars of paint, unfortunately, untenable.
              3) We've looked at domestic sources for paint, but again, the projected unit cost always ends up considerably higher than the ol' pint at Home Depot.
              Where possible, we try to select colors for new planes that use off the shelf colors, so pilots can use Tamiya or Testors from their local hobby store. But until the challenges cited above are mitigated, I'm afraid we're at an impasse. If any of you have any ideas, as always we are all ears!!
              • Prowler901
                • 940
                • Gunnison, CO
                Thanks for the details, Alpha! That all makes sense from the business position. Would it be an option to share the paint codes? Or, mixture ratios to get the color matches? That way we could take that to say the local "paint store" and have them mix it up for us. Of course different paints and sheens are going effect the color, but at least it would be in the ball park.
                • StormyDog1962
                  • 338
                  • Naperville Illinois
                  Not to mention that many times planes will vary slightly from lot to lot as the person mixing the paint may not measure exactly the same each time so even if we had some touch up paints it may still be off a bit. Taking them in to have the color matched up works pretty good in most cases but also look at Model Masters and Tamiya paints for some good options.
