How To Get Rid Of That Basketball/Alligator Texture?
    We ALL know that look. Our foam aircraft might be in the Sun a bit too long and the next thing you know that nice smooth foam texture looks like the texture of a basketball. The cells rise in heat and can make your model look like crap in a hurry.
    I've been painting my Freewing F-16C 70mm V2 the Arctic Camo livery today. It's been going great up until the moment I thought it would be smart to take it out of my garage (40 degrees or so) tonight and next to my fireplace just to expedite the paint drying so I can move on to the next phase. Apparently I didn't consider having it a few feet away (electric fireplace) would cause portions of the wing closest to it to bubble up within minutes. Clearly, my mistake. So now I have a portion of the starboard wing that looks like the texture of a basketball. So my question is:
    Does anyone have a really good method to reduce the basketball/alligator skin effect to foam that has been exposed to heat/Sun?
    I'm thinking maybe sanding with a light grit sandpaper, priming and repainting the area? Or does someone have a tried and true method even better?
    Sand lightly, prime and paint is about all I have ever had success with. I ripped the nose gear out of my F-86 and used a heat gun to help re-expand the foam which caused some minor gatoring. Sanded, primed and repainted and you could hardly tell it ever happened when done. I haven't found any other way to get rid of it. Maybe a light skim coat of filler would help as well.
    • Lon
      • Jul 2014
      • 1202
      • Miles, Iowa
      yes, sand lightly and prime. My 86 doesn't have alot of hours in the sun. But the gatoring effect hasn't shown....yet.
      Lon
        Thanks, I will sand/prime/paint... Ah the joys of foam. ;)
        • RRHandy
          Instructor Pilot
          • 896
          • Lilburn GA
          Easier to repair than balsa thou. ;)
          AMA 424553
          • Pogo
            • 452
            • Waterford, Ontario, Canada
            Lon, your Sabre looks great, and no gatoring. That's interesting to see because I'd eventually like to repaint my 80mm A-10 in the darkish green Desert Storm (previously Euro) camo but was concerned about the gatoring/ basketball thing happening. Alpha's F-14 with it's dark blue looks fine too, so maybe darker colors are OK. I only have a silver FW Venom so haven't much experience with FW foam, though the black of the ejection seat and panel hood sure went nasty, though I suppose the temps under the canopy get pretty high.
            Aros, just tell yourself "sanding is fun, I like sanding"
            Tom
            • dahawk
              Augermeister
              • Jun 2013
              • 1006
              • Keller,Texas
              One thing you might try. Take a big soup spoon and put in the freezer for about 15 minutes. Rub the affected area with the back of the cold soup spoon. I do this in conjunction with the hot water treatment when repairing dents and such in foam. Of course, the heat causes the foam to bubble. Once I get the shape back to where it needs to be, I use the soup spoon technique to take out the gatoring. Works like magic.
              Hawk
                Interesting! I will give that a try! Thanks!
                • Pauly
                  Just Fly It
                  • Apr 2015
                  • 469
                  • Warsaw, NC
                  dahawk, I need to give that a try. Thanks!
                  Still Learning:D
                  • Kloverzero
                    JetManMichael
                    • Dec 2015
                    • 513
                    • Conway SC
                    I am going to try that tonight on my 1500mm Razorback!! Headed to the freezer now!!!!
                      Okay I tried the cold spoon technique. I put the spoon in my freezer for about a half hour. Took it out, and it was awfully cold alright. I pressed the back of the spoon down on the gator skin and there was initially a noticeable effect. It does indeed relax the bloated cells, but at least for me, it didn't remove them altogether. They appear a little flatter than before, but still pronounced. I was going to show a before and after photo but frankly there wasn't any noticeable difference in the photos, mainly due to angle and lighting.
                      So I put the spoon back in the freezer and I am going to let it sit for a few hours then try again. It may be a multi-step process. Stay tuned...
                      • Kloverzero
                        JetManMichael
                        • Dec 2015
                        • 513
                        • Conway SC
                        Maybe if you put some liquid nitrogen on it?? LOL
                          THAT just might work. LOL
                          • Kloverzero
                            JetManMichael
                            • Dec 2015
                            • 513
                            • Conway SC
                            You probably have to warm it up first, with some hot water, then get it to shrink back with the cold...maybe...shot in the dark...who knows....:Confused:
                            • Dewey H Lee
                              WARBIRD JUNKIE
                              • Apr 2015
                              • 919
                              • Fayetteville NC. US
                              Could always try it on an old part laying around somewhere. That way you wont have to worrie about compounding the effect. I have popped them back in shape with hot water but never tried the cold. How about an ice cube. A little messy but it shouldnt effect the paint
                              Dewey l
                              • jetlag
                                • May 2015
                                • 53
                                Use the computer spray cleaner can upside down, i use i to freeze bees when they get in the house. Than spoon it flat
                                • dahawk
                                  Augermeister
                                  • Jun 2013
                                  • 1006
                                  • Keller,Texas
                                  Yes, it should be warmed first to get those molecules excited, the cold spoon immediately after.
                                  • crankestein
                                    • 316
                                    Interesting stuff about heat and the cold spoon.
                                    • Blewbayou
                                      • 42
                                      I had a dime size dent, tried the hair dryer and wet cloth, brought it up some, but it alligatored around it about the size of a coffe mug base. I kept moving it around and the cloth wet. Didnt work for me, probably my technic.
                                      i ended up sanding it alittle and used light weight spackle. After some trial and error on trying to match the paint, i got it done. Looks as good as new and paint match is really close. Next is varathane and never know it had an issue.
                                      • 401 FOOT CEILING
                                        I need 5 gallons of prop wash, please.
                                        • Jun 2017
                                        • 42
                                        • West Linn, Oregon
                                        Read somewhere about mixing baby powder with household latex color samples and rolling the paint on, lightly sanding and then priming before paint. Thought I bookmarked the article....
                                        Here it is:
