Im having trouble with my tail wheel breaking. even if I land very gentle it just don't hold up. Is there a fix for this/ Im not buying anymore. I love this plane but I need to find a solution. Thanks. B
1400mm F4 Corsair tail wheel.
Re: 1400mm F4 Corsair tail wheel.
Hey bhouck
Had the same issue with my 1400mm Corsair. Wheel broke right at the base. Just take a small drill bit about 2mm and drill through the base of the tail wheel. Then drill up through where the tail connects to the fuse. Then thread a long screw through the wheel assembly up into the fuse. Since its hard plastic it will hold. Hope this helps.[align=left]........And I\'m \"5 by 5\"........[/align]
