Vampire dh100 hobbyking
  • Vampire dh100 hobbyking
    Quelqu'un a t'il les bon reglages pour le vampire merci d'avance cordialement
    I use 10mm up and down for the elevator, with 30 % expo, 12mm up and down for the ailerons, no expo, and I reduced the nose wheel travel by half, and use 60% expo on that.
    For the CG, if you look on the underside of the wing just ahead of the tail booms you will see a small square formed by intersecting panel lines, that makes a good reference for the CG.
    Bon chance!
      Merci pour vos informations elle me seront précieuses bon vols
        This is a super weak spot. I'm strengthening the nose super solid this time.
