Hi Folks Just sitting here in the wet Canadian north contemplating brushless motor numbers. I understand that the KV rating means max. RPM per volt available to an unloaded motor.
I also understand that the higher the amperage the more power she will be putting out. Amperage x volts = power in Watts.
If I see motor described as 3648-770KV how do I interpret this? Could someone help?
Thanks!
Thanks!
