Pandora nose gear plastic housing
  • purduephigam
    Jet degenerate
    • 352
    • Plainfield, Illinois
    Hey all, had a few "drop in" landings and needless to say I cracked the bracket that houses the nose gear. Everything is in tact, but it flexes when under duress (causing erratic behavior when throttling on takeoff). I was considering just fabricating something similar to a back plate with a window to allow for access of the control arm. Not sure how I would secure it, perhaps use a drill bit to fabricate peg holes and glue into place? I don't see it on the spare parts list, and even if I did, I'm not sure I'd be able to access it without tearing apart the plane. Any advice?
    The bracket is part of the nose gear. See attached link
    • purduephigam
      Jet degenerate
      • 352
      I did a bad job explaining the issue. The housing that the bracket attaches to is what cracked. So now it flexes upon load. I attempted to brace this with some wood, which surely will fail again if I continue to land hard like I have been. I'll figure out another fix later if it's necessary.
      And since I had the plane on the bench, I figured why not throw in some flaps?!
      • boomer108
        Chief Boom
        • Apr 2014
        • 868
        • Chicago IL.
        That should work from what I see. I was going to suggest if that fails to get a piece of aircraft grade aluminum and epoxy it in place. That should work. Good luck!
        Roy B.
        • purduephigam
          Jet degenerate
          • 352
          I was thinking about that actually. Just wasn't sure where to get it.
          • boomer108
            Chief Boom
            • Apr 2014
            • 868
            • Chicago IL.
            Try your local hobby shop or hardware store they should have some.
            Roy B.
