Pilot Painting Service
  • Sundowner f4 Click image for larger version
    AMA 1102566
    • Not happy with this at all. Helmet is so small it makes making masks impossible and I have to freehand everything. My opinion might change in the am but for now I think it looks like ****.
      AMA 1102566
      • I used to paint 25mm metal miniatures (6 ft tall person represented by 25 mm {slightly under an inch} tall figure)
        You can't do any masking on those, you have to freehand it all.
        I plucked an eyelash hair and glued it to a toothpick for detail work.
        Everything done under a magnifying glass.
        Not the style stuff you are used to... but you can get the details to your normal standards shown on the other figures you've done.
        • Yeah I paint 28mm figures too. Straight lines are the hardest. It looks ok and the owner is happy so I will stick with it. I don’t mind doing helmet designs but I need masks.
          I build terrain too.
          AMA 1102566
          • Open bench again. Send your goodies in before it gets warm!
            AMA 1102566
            • Even in 4k at 60fps for the nerds out there :)
              AMA 1102566
              • Originally posted by AkumaZeto View Post
                Ben they look amazing!! Thanks!!! I’ll send you my cockpit 3D parts whenever they come in from Motionrc
                  AMA 1102566
                    AMA 1102566
                    • Amazing! The subtlety is perfection.
ID:	131440Click image for larger version
                        Company that makes this kit needs to re design the ammo box with the correct C Knuckle for the pin attachment to the lower rail on the Spandu. I used a little styrene rod to make a brace.
                        AMA 1102566
                          AMA 1102566
                          • Looks good Ben. Are those the ones from iflytalies? Standard or deluxe?
                            • The guns are deluxe and I think the ammo can is standard because well frankly its poo. Going to start some rusting
                              AMA 1102566
ID:	131578Click image for larger version
ID:	131579Click image for larger version
ID:	131580Click image for larger version
                                AMA 1102566
                                • Shutting down pilot service. Its been dead for months. If you need something pm me.
                                  AMA 1102566
                                  • If you are up for doing a couple JHH pilots for the F-4, I will gladly send them your way!!! Can't get bored, right?? I will PM you later and we can work out the details! Thanks! Jerry
                                    • I am going to get a 1/10th scale bomber crew from Europe, (GB, maybe?) Would you want to paint those guys? 5 to a set. Maybe getting two sets since it is a big B-17G
                                      • Feel free to pm me. I have asked that the thread be closed for now. If anyone wants something done please pm me. This is not a permanent closure.
                                        AMA 1102566
                                        • Hi guys. I just need to put here that if you are going to drop ship me stuff please send payment right away. I dont like holding on to peoples stuff and as all of you know my turn around time is often less than a week sometimes it goes out the same day it came in. I just dont want to be peoples storage as I have a ton of stuff myself here. So if I receive items and dont get payment within 30 days of getting stuff I gotta post it publicly that you have 7 days to either send return label or payment or I gotta pitch stuff in the trash.
                                          I run a commision business and have a ton of peoples stuff at my house in a cue but if I dont have funds I cant work on your products.
                                          thanks and have a great summer!
                                          Ben
                                          AMA 1102566
