Effects of cold weather
  • Lon
    • Jul 2014
    • 1201
    • Miles, Iowa
    Sun is shining.....little or no wind....Let's go fly!!!!!
    Oh, and it's 25 degrees out....
    Would I have to be concerned about the temp???   Do servo's or motor not like the cold?? :huh:
    Lon
    RE: Effects of cold weather
    Lipos definitely don't perform well in cold weather especially below freezing. Might just as well derate its capacity by 50%. Electronics like Rx,Tx, motors and servos are for the most part not affected that is unless you are gonna be flying in Antarctic conditions(-50 degree F).
    • Lon
      • Jul 2014
      • 1201
      • Miles, Iowa
      Thanks for the input.
      I did go and fly.  Only issue I had was some cold cheeks when done.  Had gloves on, and that was a little adjustment as far as feel of the controls.
      Lon
      • trying2fly
        • Jul 2014
        • 44
        I see no difference in outside temp if the battery(lipo) is 78 degrees or above at lift off.  Keep it in a styrofoam cooler, get to where you want to fly, put in and fly immediately.!!!
          Same here. When I know it's going to be really cold in the morning, I put my lipos inside the house the night before flying to bring them up to 70's ambient temp.
          • trying2fly
            • Jul 2014
            • 44
            Another little tip when you want to fly in super cold weather and get your time in......Micro wave a couple baseball sized rocks and drop them in your styrofoam cooler and batteries will stay warm for 3-4 hours.  You will see no real reduction in flight time....you'll get cold before your batteries give out!!
            • Rocketeer
              • Feb 2014
              • 1356
              Greetings,
              Indeed, LiPo's are surely the weak link when it comes to cold(er) weather flying.
              I like to stack my LiPo's in an air-tight, insulated ABS gun case and keep it inside until it's fly time.
              Has worked so far....
              Bill L.
              in Okla.
              • trying2fly
                • Jul 2014
                • 44
                Originally posted by Rocketeer
                Greetings,
                Bill L.
                in Okla.
                That is a smart move...never thought about that!!
                [hr]
                One fellow I knew put his batteries in a glove box in his car with one of those football "handwarmers" he got from Academy and lasted all day long
                [hr]
                Neat!!!
                  • 7333
                  I guess it just goes to show you, where there's a will, there's a way!
