Going ahead with 4000s. Only 2 in parallel as OV10 has done
Parallel batteries
I have been using two 2200 3S packs in parallel in my 6lb Sig 1/6 scale J-3 Cub with a 3515/14 Cobra motor successfully. I get a safe 6 minutes with aerobatics and up to nine minutes mostly cruising , depends on condition of the packs. With my Aurora 9 and Optima receivers with SPC connections, I get in flight motor battery read-out on the Aurora touch screenComment
Very cool, now that I have everything set up, I am getting 7.5-8 mins to end the flights on storage voltage. I like the Aurora system, from the bit I seen and read about. :)Comment
