Plane storage and work area
  • Hippie 64
    • Feb 2014
    • 1049
    • Gaffney , S.C.
    Not sure how any of you store or work on your planes but this is what I've done . The two stands work really well and different sizes to help with small and larger planes .
    Bryan
    But Crashing is Landing
  • wpmay
    Hobby Squawk Pilot
    • Nov 2014
    • 56
    • Charleston SC
    RE: Plane storage and work area
    Nice job! Did you use 1" PVC pipe for your stands?
    Bill M.
    • Lon
      • Jul 2014
      • 1201
      • Miles, Iowa
      Looking good!!
      Here's a shot of my Hanger/mancave in the basement.
      Lon
        • 7333
        As I just posted this on "All Us Newbies..." Hope it isn't repetitive.  I can't take responsibility though, the wife did it for me while I was at work. So then, I decided to put the old boxes to use, looks greaT!
        • doctormike
          HobbySquawk Moderator
          • Oct 2013
          • 1260
          • Santa Fe NM
          Grossman 56, My wife isn't that brave! I can hardly turn around in my shop, and it's 900 sq. ft. I have planes hanging from the ceiling by there props, planes propped up in corners, planes everywhere!!! I require people to pack a weeks worth of food and a GPS before they go in there. All you guys have such neat shops. I'm jealous!!! The Doctor
          • Hippie 64
            • Feb 2014
            • 1049
            • Gaffney , S.C.
            WPMAY I used 3/4 and didn't even glue them together. If I need I can break them down really easy that way . Plus it's light enough I can just spin them around or even lean or what ever I need .
            Bryan
            • wpmay
              Hobby Squawk Pilot
              • Nov 2014
              • 56
              • Charleston SC
              Bryan
              Thanks Bryan.
              I've made some individual plane stands but I'd like to make a larger, floor standing vertical rack that can handle 3 or 4 planes. Good to know that the 3/4" is sturdy enough and I think I'll try the "no glue' version to start as well.
              Bill M.
              • CT
                • May 2014
                • 294
                Bryan
                Hey all     Nice set up there Hippie, all protected and all. My wife would hit the ceiling if I stored my birds inside. As it is I have every square inch of the garage walls and rafters being used, in addition to storing the larger birds hanging from a carport.                            CT
                • Hippie 64
                  • Feb 2014
                  • 1049
                  • Gaffney , S.C.
                  Thanks CT , the stand with planes stacked up is in the basement. My computer room is off my den upstairs and there is where I do all my work and keep everything else. Was going to put it all downstairs but she said she would never see me !
                  Bryan
                  • Rocketeer
                    • Feb 2014
                    • 1356
                    Greetings H64,
                    Great idea going vertical on the storage racks!!!
                    Much better than spreading everything out!!!
                    I like it alot!!!!
                    Bill L.
                    in Okla.
                    • Hippie 64
                      • Feb 2014
                      • 1049
                      • Gaffney , S.C.
                      Got to confess I found a picture and just built it . I was looking for ideas and Googled rc plane storage then just looked at the pics I found .
                      But the two racks I keep in my computer n RC area I just needed something so I came up with those . I really like them I just tilt or spin them around or what ever I need .
                      • hick20
                        • 26
                        I don't have nay stand yet but i am going to make mine soon.
                        4th stand is great for small and larger planes.
                        • Doc
                          Here is my storage area, a couple of coat hangers and cup hooks. :) And a couple of scratch built
                          • SOB8604
                            • Dec 2014
                            • 163
                            Finally got the planes off the floor in the finished part of my basement, was super unpractical and took up nearly the whole room, not to mention with my two dogs it was only a matter of time until a disaster occurred. So went over and hung em from the ceiling in my work area of the basement, up out of the way and out of doggie-danger!
                            Part of me wants to see just how many planes I can fit in here and there's alot of room left...challenge accepted.
                              • 7333
                              The PVC ppe method works very well, I left the nose support pieces loose so that I could angle it for different airplanes.  All the Mustangs and the Pandoras fit into it. I glued the rest together and ran a couple of bungee cords from front to back to give it some extra strength as well.  Strapped it into the truck and voila! an airplane carrier.
                              • Pheonix
                                • Aug 2013
                                • 670
                                What did you use to do this?
                                • SOB8604
                                  • Dec 2014
                                  • 163
                                  Pheonix,
                                  Measured out (aka eyeballed) the distance that I would need to support the planes, used some self-tapping eye-bolts into the wood, from there just some regular clothes hangars with pipe insulating foam on them to spread out the weight a bit and reduce hangar rash. Took me all of 25 minutes to hang all 5! Super cheap and effective!
                                  • Rocketeer
                                    • Feb 2014
                                    • 1356
                                    Greetings SOB,
                                    Looking really good, Man!!!!
                                    Bill L.
                                    In OKla.
                                    • Pheonix
                                      • Aug 2013
                                      • 670
                                      Pheonix,
                                      Thanks much.  I have to do something as I have planes all over the place.
                                      • doctormike
                                        • Oct 2013
                                        • 1260
                                        • Santa Fe NM
                                        I have hung some of my 40 planes on the wall. I hammer a large finishing nail into the wall and hang the planes by the tail wheel. The nail fits perfectly between the wheel and the wire. Can't get more simple than that, and the tail wheel supports the plane just fine. It also looks cool! Doc
