Foam airplane question
  • 270win
    Flying RC for 27 years
    • 14
    • Atlanta GA
    What can be done to preserve the appearance of a new foam airplane? I've been in the hobby for a long time and always flew balsa/monokote or balsa/glass/painted models. With those planes, you could transport them without worrying about dents, dings and paint coming off for the most part. Is there anything that can be done to EPO planes to at least keep them from losing paint while changing batteries? I like the advantage of almost zero build time and the pricing, just want to be able to keep them looking nice long term. Thanks in advance!
  • F22trainer
    Piper PhD
    • Mar 2018
    • 1484
    • Sun City, Az
    Minwax Polycryllic-brush it or spray. I just did all of mine with a quart and have plenty remain.
    Not the Cub, but both the T6 and the PT17. Gives a nice sheen and minimizes dings, etc.
    • F22trainer
      Piper PhD
      • Mar 2018
      • 1484
      • Sun City, Az
      Oops, in all fairness Varthane makes a good WB sealer also! Stay away from spray cans and I must admit results from a good bristle brush are hard to beat.
      • boomer108
        Chief Boom
        • Apr 2014
        • 867
        • Chicago IL.
        The problem with spray cans is the propellant used to disperse the product,some can have a bad effect on foam. I always use a foam brush and minimum three coats with Varathane or Minwax, the results are excellent.
        • BluesDragon
          RC Planes Fanatic
          • 574
          • Arizona
          yup yup... ^^^ ...can't agree more with what they said. :Cool:
          Dynam; E-Flite; Freewing
          • mcriley2
            Beginner Pilot
            • Oct 2015
            • 60
            • SE Cook County, IL
            One of the good things about both Minwax and/or Varthane is depending on the type of finish you're looking for, you have that option. Matte or Satin will keep the shine down. But if you're looking for shiny, semi-gloss or gloss is available. One other thing to consider, for parts that comes off on a regular basis like battery compartment hatch, cockpit hatches should be done by themselves so they won't get sealed shut when dry. But as stated earlier by F22trainer and boomer108, best to stay with brush at least for the first two or three coats, after that you may be able to experiment with spray. By that time you should be protected enough from spray chemicals ...
            Straighten Up - Fly Right
            • 270win
              • 14
              • Atlanta GA
              Awesome responses, thanks for the advice y'all!
              • borntoolate
                Bomber Bob
                • Mar 2013
                • 424
                • California
                You can avoid the propellant issue by using the water based formulas . I always airbrush my planes with water based MinWax. It dries fast, is easy to clean up and looks great whether it is gloss, satin or matte.
                Bob
                • 270win
                  • 14
                  • Atlanta GA
                  Bob
                  Do you have to tape the model better for spraying or is the prep about the same?
                  • borntoolate
                    Bomber Bob
                    • Mar 2013
                    • 424
                    • California
                    When I use tape, I use the yellow Frog tape and stick it to my shirt or pants a couple of times. Then I paint. I peel the tape off slowly and horizontally. I never lift it 90 degrees from the painted surface. I peel it slowly back over itself and have had good luck with no peeling.
                    For prep prior to painting, I clean the plane with de-natured alcohol to remove and dust or fingerprints and oil from hands.I do not do any sanding normally. I hope this answers your question.
                    Bob
                    • BILLY BOY
                      • Apr 2018
                      • 87
                      I have also noticed that some of my older models are beginning to yellow. These are models that I have not yet had a chance to coat with water based sealer. I may have to repaint them before I brush on my sealer. The old parkzone SuperCub S and the Icon are especially prone to yellowing.
                      • 270win
                        • 14
                        • Atlanta GA
                        Bob
                        Yep, that's what I was asking. I'm doing mine this week. Thanks!
                        • ianwhitew
                          • Oct 2021
                          We can recommend EPO aircraft epoxy paint.
                          • quitcherbitchen
                            • 922
                            • Altadena, CA
                            The newest way not to let the frogtape peal paint is to wipe what you are taping with baby powder. I was recommended this by someone on the jet threads and believe me when I say "it works" No pealing. You don't even need to pre stick to your pants. The powder is just wiped on and then off. Then tape. Then paint. Then peal the tape slowly. No pealing of the paint below. Super easy. Any powder you cant even see when your doing it, but the residual must do something as it is crazy hard to screw it up.
