Guides & Info for Beginners
  • rtwatkins
    Unusual Attitude Recovery Specialist
    • 110
    • Vancouver, WA
    Welcome to the world of RC flying!!
    Hopefully a mod will sticky this thread ;)
    As this is the Beginner Q&A area, let's get a thread going with information on how to get started in hobby! kind of a "which I had known this/done this when I started" kind of thing. I'll kick us off:
    I would HIGHLY recommend you watch the following web-series:
    https://www.youtube.com/watch?v=COiN...1vn-sjBGOkJFHV (if this link doesn't work, look up "Flite Test Beginner Series" on YouTube)
    This will get you into the terminology & basic understand of how an airplane works, as well as the basic components of an RC model. It will also give you a How-To tutorial of starting from scratch learning how to fly! GREAT group of people, and wonderful information!
    Also, get with the AMA!
    The Academy of Model Aeronautics is a nonprofit community of enthusiasts who come together to celebrate model aviation.
    This is another great resource, and will provide the do's & don'ts of RC flying. There are rules for flying, and you can get yourself in trouble if you don't follow them!
    They also have a list of clubs in your area that you can get together with
    Hope this gets you started! Any other veterans want to chime in?? :D
  • mcriley2
    Beginner Pilot
    • Oct 2015
    • 60
    • SE Cook County, IL
    There is so much that I have been able to learn here on the different aspects of RC, except for one thing and maybe it's because I may be overlooking something. What is the basic formula for putting together the proper power system. Where can I go to find out what motor will fit into certain plane frames and how to chose the right components to go together?
    Most places I go to, sounds like - "blah, blah, blah, kv, blah, blah, blah, volts and amps and blah, blah, blah. :Confused:
    What I need is advice for idiots ...
    Straighten Up - Fly Right
      There is no general "cookbook" on power systems for idiots.
      Your best advise as far the forums are concerned has been from threads related to a specific airframe..
      There is really only one fundamental "formula" when it comes to power systems and it is not even a formula but more a general "rule of thumb".
      It is a general power guideline known as the Watts per Pound Rule.
      Hope this helps get ya started in the right direction. ;)
      Best regards,
      • fhhuber
        • Aug 2015
        • 1476
        There is a general correlation of power:weight to aim for when seeking certain performance levels.
        Low performance, marginal for RC flight is appx 0.3:1 power:weight. At this low level rising from ground might require a headwind, but a modest rate of climb is possible. The only way to do aerobatics is to trade altitude for airspeed.
        Trainer level performance is app .75:1 power:weight. This is easily enough for takeoff and should normally be capable of a loop from level flight.
        Sport aerobatic performance (ability to perform several maneuvers in a row) require 1ppx 1.2:1 to 1.75:1 power to weight.
        3D aerobatics requires 2:1 for vertical acceleration out of a hover. More power is almost enough...
        For EDF, you need 1.5 X as much power:weight for the same performance as a conventional prop.
        100 watts per pound is fairly close to 1:1 power:weight, with appropriate propeller choice.
        Then we get into determining which propeller....
