FMS Flap servo question
  • brick47
    • Feb 2013
    • 54
    i need a servo suggestion for Flaps for my FMS T-28. i guess i need 1 positive & 1 reverse ?
  • coot83
    • Mar 2013
    • 43
    Re: FMS Flap servo question
    I assume this is on the 1400mm version? I have actually used eflite servos for some of my FMS birds that needed a servo replacement. Im sure some hitec servos of similar size will work just fine. Also if you are having a problem getting them to be opposite you could also buy a reverser Y harness and that way one will be different. Make sure you check to see if the servos are both sitting in the same direction on the wings for the flaps. If they are on then they probably wont need a reverser.
    Coot
    • ryramZ
      Pilot Ryan
      • Dec 2012
      • 814
      Coot, that's exactly right. If the flap servos are in there pockets facing the same way a reverser won't be needed.
      • ryramZ
        Pilot Ryan
        • Dec 2012
        • 814
        http://www.motionrc.com/fms-1400mm-t-28-9g-flap-servo/
        Check this out. It's the slowed down flap servo exact replacement.
        • brick47
          • Feb 2013
          • 54
          thanks for the info guys. due to the mounting...gonna have to reverse one.
          i do like those slower servo's !
          • tom_pixel
            • Jun 2013
            • 5
            With My Jr 9503x or 11 Tx , you have the option of "delayed" flap movement , with various delays in seconds
            I think some of the other Tx's on the market , have this feature
