i need a servo suggestion for Flaps for my FMS T-28. i guess i need 1 positive & 1 reverse ?
FMS Flap servo question
Re: FMS Flap servo question
I assume this is on the 1400mm version? I have actually used eflite servos for some of my FMS birds that needed a servo replacement. Im sure some hitec servos of similar size will work just fine. Also if you are having a problem getting them to be opposite you could also buy a reverser Y harness and that way one will be different. Make sure you check to see if the servos are both sitting in the same direction on the wings for the flaps. If they are on then they probably wont need a reverser.
Coot
