I installed safe select on a T28 to an on and off switch. When I switch back and forth the alerons and elevator fluctuate. Any help on this?
Safe select on and off
Yes more info, it does move the surfaces when the gyro initializes. Once done it should fly as normal. If it is continuing to move then there's something wrong.Comment
Yikes! Man i am not sure, do you have the software to check settings im not sure how it works, as all the safe select aircraft i have come with it stock. I would think you may have to program it to the plane if it didnt actually come with it.Comment
Hey Bogie,
I'm not exactly sure what you mean by, "installed safe select"? Which T-28? If it's the little park zone T-28, it comes with AS3X, and Safe out of the box. If it is the Park Zone T-28 you need to follow the instructions very accurately. The thing I messed up on was, you need to make sure this plane is sitting up right on the main landing gear for about 30 seconds prior to binding, (a little longer wont hurt). I believe the instructions direct you to set it to a specific switch on your transmitter. Just follow the book, make sure you set the plane level on the landing gear for a bit after connecting the battery, this is critical. When the safe is on the servos are always a bit jittery. Move the plane around in your hand to see if there responding correctly. Then sit it down to see if everything settles down.
If this is another T-28? As previous posters have said, we need a little more detail. Good Luck!
Best Regards
WoodyComment
Amen...Hey Bogie,
Best Regards
Woody
sound adviceComment
