Project Five Eyes Guesses
  • F22, I’m sure you’ve seen the mods in more detail on the AT-6 post. 4s really lights this airframe up but it still flies great slow. You can always adjust the CG to suit your personal tastes. This airplane has become my personal favorite beater airframe. Not that I abuse it but I like to fly it regularly given it’s a taildragger of reasonable size and cheap compared to other models I operate. It’s a perfect airplane to practice slow scale like takeoffs and landings with. I enjoy it quite a bit...
    • well I think its odd that they reduced the price on the fms fw190a and not the rest of the line. would be funny to have the old fw190 for sale for 320 and the new one for 360. I also know that the wild boar's (mostly fw190) were the night time eyes of Germany? I don't know if there were five
      • Originally posted by Ole-Timer View Post
        What motor did you end up using in it?
        • https://www.motionrc.com/products/fl...t-power-system
          The information below and more is on the New Eflite AT-6 post...
          Due to the larger airframe and slightly added weight of the AT-6, I have pulled both stock esc and motor out. I installed a 60amp Turnigy Plush esc with a FlightLine 3648-880kv motor and will run those on a 4s 4500mAh battery. I can now also use a 12” prop to help get around the big cowl. The airframe is plenty big enough to handle it all and any added weight will be welcome on windy days. Don’t know if any of you have weighed the stock spinner on this plane but at 2.5ozs it’s another bandaid to add nose weight flying a small 3s system on what should be a 4s bird.
          Ill use the stock motor n esc to power a smaller model.
          Amp tests with a 12x8 prop
          20amp 1/2 throttle
          36amp 3/4 throttle
          55amp wot
          • I think it was a Typo. Five Guys I believe is what he meant. Just saying
            • Yes
              Stay focused and on thread.
              I think I’ve run aground with all the nebulous clues guesses and now lean toward wishful thinking.
              Seeing the images from the wreck of the Lexington make me wish for a big Devastator. Just be nice to see something different rather than Corsairs, Mustangs, and all the other regularly modeled warbirds.
ID:	162495Click image for larger version
ID:	162497Click image for larger version
              • A Devastator would be just awesome!!!
                  Yes
                  Those look dumped overboard after the war.. R.
                  AMA 424553
                  • Ugh
                    Now I’m thread bashing again...:( sorry
                    Lexington was lost in the Battle of the Coral Sea in 1942 and sank with 35 aircraft on board.
                    Water pressure during her plung swept the aircraft on deck overboard.
                    They are laying on the sea floor around her wreckage.
                    Devastators and Wildcats were used at the beginning of the war and that’s what we’re seeing here.
                    Had they been aircraft that were dumped overboard after the war we’d be looking at 1945 ... Corsairs, Hellcats, and Avengers.
                    https://www.paulallen.com/uss-lexing...ted-rv-petrel/
                    Click image for larger version  Name:	954620EF-3DE5-44F7-B379-4A5386B78122.png Views:	1 Size:	881.8 KB ID:	162598Click image for larger version  Name:	47018AF5-F0E0-437A-8980-37867DAEBF27.png Views:	1 Size:	1.35 MB ID:	162599
                      Ugh
                      Or blackened and partially melted in the case of the Saratoga (CV-3)
                      • I'm going with a Mosquito. Reasoning is it's not an EDF, many PR versions had 4 vertical and one oblique cameras for a total of 5 "eyes", or you could read Mk.VI's or VI's or VIII's version as 5 iii's. Hows that for logic! personally I'm hoping it's a FB Mk.VI version. We desperately need a new accurate large Mosquito. Put me down for at least two so I can have a bomber as well as Fighter Bomber version.
                        • Originally posted by Beeg View Post
                          What about the Hornet, which looks like Mosquito wings with a single person cockpit and shorter fuselage?
                          • Originally posted by Valkpilot View Post
                            DH103 is on my wishlist but I can’t work it into the “five eyes” project name.
                              There were only five of the recon version built for the RAF!!!:Cool:
                              • I hope if it isn't a B-29 then it has something to do with Sk"eye"raiders. Here is my Durafly from yesterdays operations.
                                • I am just hoping there are more 2m super scale releases. I know we need planes of all sizes for cost and transportability, but I do hope the upper end of the model size is more like the FW A-10 and B-24 wing spans.
                                    I was thinking along the same lines. Frost's "The road not taken" could with a little bit of imagination portray DeHavilland's choice to "take the road less travelled" when they developed the Mossie (mostly from wood...) without any request or specification from the Air Ministry.
                                    Also "finicky" and "I took the road less travelled" could indicate a more exotic bird. But it would also need to sell in numbers so I doubt it will be extremely rare.
                                    • You're forgetting the all terrain aspect
                                      • Originally posted by MANFRED View Post
                                        That is another project that is also prop driven according to Alpha.
                                          You’re absolutely right about that!
