Here is the latest member of my Dynam planes, with a 42-38 motor, 85 ESC (Gecko) and a Master Air Screw, 3-blade 13-8 prop. I added light and 2-coats of Hobby Coat for the finish. An Admiral 3600 battery puts the CG right on recommendations. I need the Spitfire to complete the fleet that I want, which I will be ordering soon.
New Dynam p47
Pheonix, after some time of flying the P47 what's your input on it? I'm thinking of getting one as my first low wing and war bird.Here is the latest member of my Dynam planes, with a 42-38 motor, 85 ESC (Gecko) and a Master Air Screw, 3-blade 13-8 prop.* I added light and 2-coats of Hobby Coat for the finish.* An Admiral 3600 battery puts the CG right on recommendations.* I need the Spitfire to complete the fleet that I want, which I will be ordering soon.*
Still Learning:DComment
Hey fellow pilots, I have a question for you. On the P47 here I know Pilot Ryan speaks of using the 3000 battery which I got for this bird, but it seems pretty tight and almost impossible for it to fit properly with out doing some cutting and carving of some sort. I guess my question is are there any of you that fly this and what battery do you use? I to was wondering just how I might be able to get to the front and carve out seeing how you can't really get to it inside the plane. I feel like a bigger battery would be the key thing to use and with a little velcro on the bottom and I'm good. There is no way to add a strap not that I'm aware of.Still Learning:DComment
