New Dynam p47
  • Pheonix
    • Aug 2013
    • 670
    New Dynam p47
    Here is the latest member of my Dynam planes, with a 42-38 motor, 85 ESC (Gecko) and a Master Air Screw, 3-blade 13-8 prop.  I added light and 2-coats of Hobby Coat for the finish.  An Admiral 3600 battery puts the CG right on recommendations.  I need the Spitfire to complete the fleet that I want, which I will be ordering soon.
  • Rocketeer
    • Feb 2014
    • 1356
    RE: New Dynam p47
    Greetings Pheonix,
    Man, i'd say that is SWEET!
    But, it just doesn't seem like enough...
    Nice work!! The Spitfire will be the perfect capstone.
    Bill L.
    In Okla.
    • Pheonix
      • Aug 2013
      • 670
      RE: New Dynam p47
      Thanks much. Check back in a few and I will show you my latest project :)
      [hr]
      I finished these about a month ago and they are ready to maiden.  A3L gyros are in both.
      • Rocketeer
        • Feb 2014
        • 1356
        RE: New Dynam p47
        Greetings,
        Will Do......Anxious to see what's nest!!
        Bill L.
        In Okla.
        • Pheonix
          • Aug 2013
          • 670
          RE: New Dynam p47
          They are there!
          • Rocketeer
            • Feb 2014
            • 1356
            RE: New Dynam p47
            Greetings,
            Ok, my bad. I washed the two emails together.
            like to see a profile view if possible.
            Bill L.
            In Okla.
            • Pheonix
              • Aug 2013
              • 670
              RE: New Dynam p47
              Here are more views.  The canopy is operated by a servo.
              • Rocketeer
                • Feb 2014
                • 1356
                RE: New Dynam p47
                Greetings Pheonix,
                Sweet rides!!
                I really like the active canopy!!
                Thanks for sharing.....
                Bill L.
                In Okla.
                • Pheonix
                  • Aug 2013
                  • 670
                  RE: New Dynam p47
                  You are welcome Bill and happy flying.
                  • Pauly
                    Just Fly It
                    • Apr 2015
                    • 469
                    • Warsaw, NC
                    Originally posted by Pheonix
                    Here is the latest member of my Dynam planes, with a 42-38 motor, 85 ESC (Gecko) and a Master Air Screw, 3-blade 13-8 prop.* I added light and 2-coats of Hobby Coat for the finish.* An Admiral 3600 battery puts the CG right on recommendations.* I need the Spitfire to complete the fleet that I want, which I will be ordering soon.*
                    Pheonix, after some time of flying the P47 what's your input on it? I'm thinking of getting one as my first low wing and war bird.
                    Still Learning:D
                    • Pauly
                      Just Fly It
                      • Apr 2015
                      • 469
                      • Warsaw, NC
                      Hey fellow pilots, I have a question for you. On the P47 here I know Pilot Ryan speaks of using the 3000 battery which I got for this bird, but it seems pretty tight and almost impossible for it to fit properly with out doing some cutting and carving of some sort. I guess my question is are there any of you that fly this and what battery do you use? I to was wondering just how I might be able to get to the front and carve out seeing how you can't really get to it inside the plane. I feel like a bigger battery would be the key thing to use and with a little velcro on the bottom and I'm good. There is no way to add a strap not that I'm aware of.
                      Still Learning:D
