I have a dual charger that works great.
Recently, I purchased a multi adapter for charging; it has a whole bunch of different adapters all on one harness.
As I was charging my 4000 mah battery on one channel, I went to hook up my 800 mah on the other channel, and by accident, hooked it up to the same channel and harness as the 4000mah battery.
Pop! Sizzle! Smoke! and a scream!
Cut power and went to get the fire extinguisher but both the smoke had stopped and no flame.
The deans connectors fused together and the wire for the deans adapter melted a little bit.
Upon separating the deans, looks like it damaged the pin on the battery side.
Lesson learned....when using multi adapters be careful not to get lost in the jumble of wires.
Also, hook both batterys up at the same time to the charge, do not connect one while the other is charging even if using the correct charging channel.
