Anyone have a good way of removing the factory decals from the Rebel EDF? I'm going with a USAF or NAVY theme.
Removing Decals
The decals pull the paint under them... because the bond of the decal to the paint is stronger than the bond of paint to EPO.
That will always result in the outline of the decal being left. You have to find a way to "fair" the edges. I use a paper towel and acetone. (caution, make sure it really is EPO, because EPS will be destroyed)FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
Ok, I will try that. MRC describes it as "Durable EPO foam".The decals pull the paint under them... because the bond of the decal to the paint is stronger than the bond of paint to EPO.
That will always result in the outline of the decal being left. You have to find a way to "fair" the edges. I use a paper towel and acetone. (caution, make sure it really is EPO, because EPS will be destroyed)Comment
Use tape to pull them up! Packing tape, duct tape, sometimes even masking tape. If they're waterslide, that'll bring them right up! May also work on yours.Comment
1 PhotoComment
I dampen a paper towel in acetone, then rub to feather the edges of the paint border between lifted and not lifted... and it removes any remaining adhesive.
I've never pulled a decal from an EPO model without it lifting any paint that was under it.
Again... other foams will get eaten by acetone.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
Thanks for the tip. I will the acetone and see how that works. There is not too much left over adhesive so it shouldn't take much effort to get it off.I dampen a paper towel in acetone, then rub to feather the edges of the paint border between lifted and not lifted... and it removes any remaining adhesive.
Again... other foams will get eaten by acetone.Comment
Acetone and MEK will not harm EPO, with that said MEK if left to long on it will make is spongy flexible but when it gasses out it is fine. I stripped an LX B-25 this way, then I stripped an LX F4U Corsair with acetone and that had no effect at all. :Cool:AMA 424553Comment
+1 on paint over them , a little flat latex paint or primer with a light sand and the edges vanish, smoother than the foam. Pulling them off often leaves a rough surface which makes for allot of work to smooth out.
Like the shape of the rebel allot, she's going to look sweet with a repaintrc flyin addictComment
I always repaint over factory. Like you say it's a lot of hassle to smooth out the rough surface texture (and match the surrounding areas) once removed. Prime, sand, prime and paint. Works like a charm.+1 on paint over them , a little flat latex paint or primer with a light sand and the edges vanish, smoother than the foam. Pulling them off often leaves a rough surface which makes for allot of work to smooth out.
Like the shape of the rebel allot, she's going to look sweet with a repaintMy YouTube RC videos:
Thanks guys, I got all the decals off last night so now i will gently try to work off the reside with acetone. Once that is done I will prime and paint white like the T-38 USAF jets. I will post up as I move forward.Comment
