Removing Decals
  • CVA59
    A4 Driver
    • Nov 2018
    • 398
    • Texas
    Removing Decals
    Anyone have a good way of removing the factory decals from the Rebel EDF? I'm going with a USAF or NAVY theme.
    EAA# 1366802
    AMA# 631508
    https://vf59.weebly.com/
  • Quickstop
    • 275
    I believe most people paint right over them (I do)
    • Ron1950
      Retired ATC
      • Oct 2015
      • 887
      • brandon ms
      someone on facebook said he got them off his rebel by heating with a hair dryer and packing tape removing it carefully
      • CVA59
        A4 Driver
        • Nov 2018
        • 398
        • Texas
        Thanks guys, I will it with heat first.
        EAA# 1366802
        AMA# 631508
        • Quickstop
          • 275
          99% chance you will bubble the foam if you apply heat, quite possibly the worst advice I've ever heard. Believe me, it only take a tiny bit of heat to permanently damage the foam.
          • Skyboom
            Foam flyer
            • Nov 2018
            • 344
            • Chilliwack, British Columbia, Canada
            I did the same. But the outline of the decals are still visible. Thinking I should have done the hairdryer trick.
            • fhhuber
              • Aug 2015
              • 1476
              The decals pull the paint under them... because the bond of the decal to the paint is stronger than the bond of paint to EPO.
              That will always result in the outline of the decal being left. You have to find a way to "fair" the edges. I use a paper towel and acetone. (caution, make sure it really is EPO, because EPS will be destroyed)
              • CVA59
                A4 Driver
                • Nov 2018
                • 398
                • Texas
                Ok, I will try that. MRC describes it as "Durable EPO foam".
                EAA# 1366802
                AMA# 631508
                • andrew_flyguy
                  Just wanna fly
                  • Jun 2018
                  • 162
                  • Nashville TN
                  Use tape to pull them up! Packing tape, duct tape, sometimes even masking tape. If they're waterslide, that'll bring them right up! May also work on yours.
                  • CVA59
                    A4 Driver
                    • Nov 2018
                    • 398
                    • Texas
                    Thanks Andrew. I will give it a shot.
                    EAA# 1366802
                    AMA# 631508
                    • CVA59
                      A4 Driver
                      • Nov 2018
                      • 398
                      • Texas
                      Works great so far. I have one half done. Is there any issue using acetone to get the left over gunk off?
                      EAA# 1366802
                      AMA# 631508
                      • Ron1950
                        Retired ATC
                        • Oct 2015
                        • 887
                        • brandon ms
                        nice ill let u do mine!
                        • fhhuber
                          • Aug 2015
                          • 1476
                          I dampen a paper towel in acetone, then rub to feather the edges of the paint border between lifted and not lifted... and it removes any remaining adhesive.
                          I've never pulled a decal from an EPO model without it lifting any paint that was under it.
                          Again... other foams will get eaten by acetone.
                          • CVA59
                            A4 Driver
                            • Nov 2018
                            • 398
                            • Texas
                            Hahaha, I better pass Ron. This one is enough for me, LOL.
                            EAA# 1366802
                            AMA# 631508
                            • CVA59
                              A4 Driver
                              • Nov 2018
                              • 398
                              • Texas
                              Thanks for the tip. I will the acetone and see how that works. There is not too much left over adhesive so it shouldn't take much effort to get it off.
                              EAA# 1366802
                              AMA# 631508
                              • RRHandy
                                Instructor Pilot
                                • 892
                                • Lilburn GA
                                Acetone and MEK will not harm EPO, with that said MEK if left to long on it will make is spongy flexible but when it gasses out it is fine. I stripped an LX B-25 this way, then I stripped an LX F4U Corsair with acetone and that had no effect at all. :Cool:
                                AMA 424553
                                • mr.frankenjet
                                  Eat, sleep, FLY FLY FLY !
                                  • 448
                                  • Virginia, USA
                                  +1 on paint over them , a little flat latex paint or primer with a light sand and the edges vanish, smoother than the foam. Pulling them off often leaves a rough surface which makes for allot of work to smooth out.
                                  Like the shape of the rebel allot, she's going to look sweet with a repaint
                                  rc flyin addict
                                    • 8205
                                    I always repaint over factory. Like you say it's a lot of hassle to smooth out the rough surface texture (and match the surrounding areas) once removed. Prime, sand, prime and paint. Works like a charm.
                                    • CVA59
                                      A4 Driver
                                      • Nov 2018
                                      • 398
                                      • Texas
                                      Thanks guys, I got all the decals off last night so now i will gently try to work off the reside with acetone. Once that is done I will prime and paint white like the T-38 USAF jets. I will post up as I move forward.
                                      EAA# 1366802
                                      AMA# 631508
