Yep I did it, after 6 flights about 10 minutes each I got disorientated and put my plan in a nose dive and couldn't pull up in time. Quite the impact, tore the battery out and flung it 5 ft from the crash. Not sure how it happened. As many of you might know things got real fast in a short time. Going over things in my head I thought while going down field the aircraft was a bit slow to respond but maybe that is me over analyzing things post crash. When I was in the dive maybe I should have let off the throttle and pulled back. I'm thinking I hit the throttle and didnt give the plane enough time to respond.
But, with some leftover EPO glue and a little painters tape to help hold things in place, I think it's salvageable. The repair was a bit tacky this morning. We shall see! I do have replacement parts in my shopping cart at Motion if things dont go as planed.
That is what trainers are for!
Kevin
Kevin
