FAA ruling
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    FAA ruling
    Well, now we have to call the control tower, AND the airport mgr. 5 minutes before we fly our "toy" airplanes and immediately when we stop! The club's air strip and the soccer field where we fly are within 5 miles of the Santa Fe airport. Now I'm going to ask the guys, before we fly, if anyone has called the FCT. ( F...ing control tower). I'm sure the control tower doesn't want to be bothered with this any more than we do.THANK YOU to the F...ing irresponsible drone flyers!!! Can you tell I'm irritated?!!! Doc
  • Pheonix
    • Aug 2013
    • 670
    RE: FAA ruling
    Yes, I can tell. LOL!
    • XF-15DCC
      • May 2015
      • 164
      • Bristol CT
      RE: FAA ruling
      Is this a local requirement? I also fly within 5 miles of a small field and we havent been directed to do anything......yet.
      Off with one helluva roar!
      AMA 1085465
      • Lon
        • Jul 2014
        • 1201
        • Miles, Iowa
        RE: FAA ruling
        I think one thing that makes a difference "Is there a control tower at the small airport?"
        If the answer is no.  Your alright to fly.
        Lon
        • doctormike
          • Oct 2013
          • 1260
          • Santa Fe NM
          RE: FAA ruling
          No, it's not local, it's the Federal Aviation Agency. However, if there is no control tower or airport mgr. I would imagine you are safe to fly without notification. This situation doesn't seem to be mentioned in the new edict. I guess the FAA, in all it's wisdom, didn't check the charts... yes, there are still airfields with no control tower!!! Doc
          • boomer108
            Chief Boom
            • Apr 2014
            • 867
            • Chicago IL.
            RE: FAA ruling
            Our club field is within 3 miles of Chicago O'Hare Intl. Airport. Our only restriction so far is 400 ft. max altitude which is in accordance with AMA directives. I really don't think after 40 years of flying there the airport tower wants us to call them every time we fly nor have they asked us to.
            Roy B.
            • doctormike
              • Oct 2013
              • 1260
              • Santa Fe NM
              RE: FAA ruling
              Roy B.
              Have you read the new FAA ruling? I'm sure the tower doesn't like this any more than we do. Unless the Santa Fe airport manager, control tower, AMA, and our club president are mistaken... Like it or not, it's coming. I'd be willing to bet this whole thing will blow over and we'll be back to normal. However, one accident while not following the FAA rules..you've had it. Doc
              • Seadog
                • Oct 2015
                • 3
                RE: FAA ruling
                I fly both planes and (drones) quad-copters. Have the Phantom 3 pro and a hex home-built plus home-built quad. I prefer the quads due to not having take of space being critical. I have a 24" tv hooked up to my hdmi port on the phantom controller and the image is stunning also the nature shots. I'm on the edge of NFZ so just about make it if I fly from home and away from NFZ. It's the irresponsible people making it a pain for us. I was worried it would overflow into the winged aircraft flights. I don't have issue with the registration since we already have to register so much including ourselves. LOL 5 miles is too far a limit. Just make the limit shorter and keep it at 400ft. I know the importance of aircraft safety. I was stationed on an aircraft carrier. That landing field is smallllllllllllll.
                • retiredflyer
                  • Aug 2014
                  • 333
                  • Sanford, Maine
                  RE: FAA ruling
                  I can tell you guys are upset and I do not blame you. I am SO glad I fly in an uncontrolled area.
                  Addicted to planes!
                  • doctormike
                    • Oct 2013
                    • 1260
                    • Santa Fe NM
                    RE: FAA ruling IMPORTANT!
                    Now, the FAA is looking into making us register our planes!!!! Unbelievable! By law, all aircraft must be registered, however model planes have been ignored up to now. Today is the last day to register your comments. I just learned about this from Tower Hobbies. Go to regulations.gov ,then to... Clarification of applicability of aircraft registration requirements for unmanned aircraft systems. Send them your thoughts on this. Try to be nice! Doc
                    • Loneflier
                      • Aug 2013
                      • 603
                      • Huntsville, AL
                      RE: FAA ruling
                      Thanks Doc,
                      I submitted my response yesterday, and specifically asked that traditional planes be excluded from registration. I just dont see how any of these registration will help. The only thing it will do is put more burden and costs on the ethical flyers. Those that are causing the problems won't bother with registration or will find a way around it!
                      • Pheonix
                        • Aug 2013
                        • 670
                        RE: FAA ruling
                        I gave my comments as well with some suggestions other than registration.
                        • Pauly
                          Just Fly It
                          • Apr 2015
                          • 469
                          • Warsaw, NC
                          RE: FAA ruling
                          Word still from the AMA is to hold off from registering at the moment until February 19th I do believe which is the last of the 30 rule. The AMA is suppose to let us know something when they know more. As they say The best thing to do any how is to put your name, phone # and AMA# on a card or something on your flying object or what ever you may fly.
                          Still Learning:D
                          • fhhuber
                            • Aug 2015
                            • 1476
                            RE: FAA ruling
                            Before it has always been:
                            Just ask the local airport to mark the chart: Potential RC model aircraft operations to XXXXX ft.
                            Yes, you can get them to mark it for 2500 ft AGL.
                            If you are out of the normal take-off and landing patterns they generally don't care as long as the RC models give way to full scale.
                            They really don't want you calling them every time someone shows up at the model airfield... They just want you to keep out of the way of full scale traffic.
                            If it causes the Airport management to get annoyed with all the calls they'll stop saying "OK, go for it"
                            If you aren't a problem and they know you have never been a problem they'll be glad to mark the chart.
                            Note that the AMA RC Pattern Aerobatics competition "box" exceeds 800 ft before the maneuver is penalized for exceeding allowed height. And that has been a standard part of the competition regulations for over 20 years.
                            No one ever complains about it... because the competitors will immediately clear the airspace if a full scale shows up.
                              • 7333
                              RE: FAA ruling
                              We're slowly getting there.
                              • doctormike
                                • Oct 2013
                                • 1260
                                • Santa Fe NM
                                RE: FAA ruling
                                The very latest from AMA is go ahead and register. Their battle may be a long one. Doc
                                [hr]
                                One of our club members called the tower, as instructed, and was told "Don't bother us!" Doc
                                • fhhuber
                                  • Aug 2015
                                  • 1476
                                  RE: FAA ruling
                                  That ruling was before FAA rewrote the rules...
